I am getting the following message when I open my Bentley View connect edition:
Requested help previously, but nothing seems to solve the problem. I can't find the send logs now feature as well. Can somebody help.
The application also shuts down after a short period.
Please open the Windows Start menu, type Bentley Licensing, and choose Bentley Licensing Tool from the results list. Then select Send Logs Now from the Tools menu.
Good day Jeremy
I did the above a few times but no success.
Diagnostic logs maintained by CONNECTION Client may explain why this error keeps occurring. Please perform the following steps to gather and submit them:
Once received, I will examine the logs for problems and follow up with you.
I am facing the same problem. I have uploaded my log as instructed.
Chee Lin Koh, there was an issue with your Bentley login that has been addressed on our end. Please confirm whether the problem is resolved now.
Hi Jeremy, unfortunately, it is still not resolved. Is there anything else i can do?
Please run LogCollector again, and submit the latest logs so that I can see if anything changed. Please reply to this post once they have been submitted.
Hi Jeremy, i ran the viewer again and it is working already. Thank you for your help.
