Try doing a clean boot then run the install. It that doesn't work try using the Microsoft Fix It tool.
If neither of those work please upload your CONNECTION Client installation logs from %temp% folder.
Miglius DambrauskasSupport Engineer
I suppose that the problem was a specific update Window 10 update 1809 and it was successfully installed after that
