Hi there, I am getting the following error continuously: 'The Licence Client was unable to contact the Usage Logging Service.' I have used the Send Log Feature and I am still unable to use the viewer. Is there a solution?
Yes, if you are encountering this issue with free CONNECT Licensing-based products such as Bentley View CONNECT Edition, please download and run the following batch file. Instructions are provided at the bottom of the page. Please confirm whether the error subsides afterwards.
Answer Verified By: steven murphy
Jeremy,
That has worked.
Many thanks.
Steven
Thank you @jeremyhoesly. We've been experiencing this since early March.
I see that 'Run as Administrator' is noted to execute the script... will running the script from any local administrator other than the affected user suffice?
Alfred McPeters said:I see that 'Run as Administrator' is noted to execute the script... will running the script from any local administrator other than the affected user suffice?
No, the script deletes two files in the current user profile, so running it as another user will not have the intended effect. I recommend running the script as an administrator on Windows 7 only because it experienced permissions problems when attempting to quit CONNECTION Client. I did not see this behavior in my tests with Windows 10.
could you please update the batch file link? I'm seeing a Page Not Found now. TIA
