I am having issues with my Bentley viewer being disabled by log send. I have tried using Send log now function in the Bentley Licensing tool but to no avail.
Hello,Please use Secure File Upload and upload your SELECTserver Usage Logs and contact me privately. To send the private message hover on my name and click on "Send a Private Message".Regards, Miglius
How do I obtain my Log files?
It can be found in your SelectServer Administration Site, Administration->Manual Log Transmittal, download the unprocessed Logs. Please see wiki: https://communities.bentley.com/products/licensing/w/licensing__wiki/13481/how-to-manually-transmit-logs-from-the-selectserver
Dominic Liew said:I am having issues with my Bentley viewer being disabled by log send. I have tried using Send log now function in the Bentley Licensing tool but to no avail.
You appear to be using Bentley View CONNECT Edition. This product has been encountering licensing problems when used with Bentley logins not associated to an organization. A fix has been implemented on our end, but the changes may not be propagating to your machine yet. To force an update, please download and run the following batch file. Instructions are provided at the bottom of the page. Please confirm whether you can use Bentley View CONNECT Edition now.
Answer Verified By: Dominic Liew
Thank you so much for your help! My Bentley View Connect Edition is now working.
