we are dismissing a PC on which CONNECT is installed and activated as "SELECT subscriber against a hosted (Bentley) SELECTserver"
We have installed CONNECT on a new PC.
Now, what we have to do to "deactivate" the old PC and to "activate" the new PC ?
Thanks a lot in advance for your help
Giuseppe
If you did not check out a license for your product, you can simply uninstall the product from your old PC so that it cannot be used anymore. To determine if a license was checked out, please open the License Management Tool included with your product, and note whether the activation status for your product displays as Checked Out. If it does, please click the License Checkout tab, select your product in the bottom pane, and click the CheckOut button to return the license.
