Trying to use /layout when creating an installation package and all i get is an endless loop when i select Next on the Deployment image settings page, it loops back to the Installation Directory page. Keeps going in this loop as many times as i push the button.
Worked fine in previous versions.
i did notice that there was only the 64bit version on the downloads page so i am unable to try a 32bit version of the client.
Anyone else have this problem?
There's a known issue with using layout in that version. This will be fixed in the next release.
Tamicca SellarsMicroStation Product Manager
I noticed this is still an issue in 10.00.14.18. It appears that you can still create a silent installation by adding a /quiet switch, but you may not get all the other options that would be available in the /layout option. For example, the /layout option would allow you to leave the box unchecked for a desktop icon.
I'd like to create an installation package for my company using this version.
I'm also trying to figure out whether or not 10.00.14.18 is a CL version or not. The Bentley downloads page shows it as CL, but if I use an older version of the Connection client and update, it does not display 14.18 as a CL version.
