Dear Support,
In CONNECT license, such command line options as below are still usable?https://communities.bentley.com/products/licensing/w/licensing__wiki/3563/license-tool-command-line-options
Best regards, Jos
No command line options for the new Bentley Licensing Tool exist at this time. What specific options do you seek?
Thank you for your reply. I was looking for the command line options for check-out and check-in. In CONNECT License, it seems it can be done by reserve and release in Bentley Licensing Tool.
When I reserved a license and set the end-date, then I checked-in (released) the license before the end-date. However, it looks the check-in did not complete in status tab even after sending logs. I wanted to make sure that it was properly checked-in.
Now the end-date has already passed, the check-in was automatically completed.
I suspect the Bentley Licensing Tool is not refreshing the page. Please upgrade to the latest version of CONNECTION Client as a troubleshooting step since it also includes a number of bug fixes for the Bentley Licensing Tool. Does a checkout and subsequent check-in clear the bottom list as expected after upgrading CONNECTION Client?
I am sorry for my late reply. In the latest version of CONNECTION Client ver.10.00.13.17, the issue has been solved. Checkout as well as check-in before the end-date have no problem.
