Since support for SELECTserver is going away July 1, 19, can I still run MicroStation V8i (08.11.09.357) using CONNECTserver? Same question for Descartes and IPLOT and IPLOT Server and drivers.
PSEGSC
Found this buried on another thread I'm following in the MicroStation Forum...
https://communities.bentley.com/products/microstation/f/microstation-forum/179170/microstation-v8i-ss10
I found a clue to what has happened. This sounds like politics at its best.
From https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/39681/licensing-openflows-products---subscription-entitlement-service-connect-licensing ,
Originally we had planned to have a Subscription Entitlement Service (CONNECT Licensing) "adapter" available, which would enable older product versions to utilize the Subscription Entitlement Service. As of December, 2018, we no longer plan to have the adapter available. To use the Subscription Entitlement Service and its related Entitlement Management features, you will need to upgrade to Subscription Entitlement Service-capable product versions. (10.02.00.01+)
Originally you were supposed to be able to request it from tech support. You could still try, but it sounds like they will not be willing to help.
--Robert
Rod WingSenior Systems Analyst
