My company has commercial licenses for Context Capture, however I can not get it to activate, it is stuck on "Non-commercial" and this is not good as it is leaving "non-commercial" watermarks on orthophotos.
I am having this issue on a Windows 10 machine running ContextCapture Update 12.
I have tried to uninstall/reinstall ContextCapture. Running the Activation Wizard multiple times (and it reports that it has activated ContextCapture). Have also went into the License Manager Tool to send logs to the selectserver multiple times. None of these things will get CC Update 12 to recognize the commercial license.
I have successfully activated ContextCapture on another machine running Windows 7 and ContextCapture Update 10. I will not attempt to try Update 12 on this machine as this is the only working machine right now.
Anyone know what else I can do?
Non-commercial watermark is also a part of projects production. You will have to reset reference model texture for the project in production mode so it doesn't leave watermarks afterwards.
Run contextcapture engine and check in text window it is correctly activated.
