I've got a computer in our office with MS U10 (10.10.00.23) installed and it seems that still using SelectServer licencing. When I installed OBD U5, the licensing tool says OBD is activated
But starting OBD U5 gives me the error of expired trial.
Does that mean MS U10 is not compatible with OBD U5?
Best regards,
Tuan Le
Hi Tuan,
Tuan Le said:Does that mean MS U10 is not compatible with OBD U5?
It's not about any compatibility, MicroStation and OpenBuildings Designer are two completely separated products based on the same PowerPlatform (engine). But for an installation and a licensing, they can be treated as independent:
What makes you situation more complicated are different versions, so:
To use OBD U5, ensure CONNECTION client is running, you are logged and OBD license is allowed to be used by your account.
There is a wiki about the new licensing.
With regards,
Jan
