Entitlement Management - User alert settings, unable to change acknowledgement
Has anyone tried applying 'User Alerts' within the Entitlement Management
Entitlement Management - User alert settings, unable to change acknowledgement.
I can apply a restriction, I tested setting the threshold to a count of 1, I wanted to check I was receiving the alert as an administrator
However I cannot change the user message to none, if I go to the pulldown nothing happens
Cheers
Chris
  • Same story. I would not trust this alerting at all. If Bentley will send bill because of some bug in connect licensing not sure if you will be able to ask to cancel it.
  • Problem is it is not users who should have such right to overuse licenses, with all these annoying connection client, connected project, connect advisor and also now this licensing alerts and popups users click randomly all buttons just to get to work session. License usage must be capped and it should be auto enabled for all customers by default so they are aware how much licenses they use and when they need more. ONLY if administrator EXPLICITLY enables for some users to allow additional usage THEN only THEN it would be acceptable. This approach is dead end and sooner or later Bentley will have to introduce option to cap license usage it is inevitable. We are losing many SELECT customers because of this as they can't accept such automatic invoice generation on accidental usage and pricing is not reasonable for such occasional usage. This warning message also is no guarantee that it will show correctly or it will work as expected for example warning can be accidentally bypassed or "Cancel and Quit" button doesn't work correctly(ST7000957341).
  • Is this still an issue?  Can the "Acknowledge" box be turned into a "All licenses in use"
  • Yes it is still an issue. Worse that some customers still receive invoice retroactively when upgrading old products like PowerMap to Map if it is done while quarter is not ended as it now shows as overusage.
Reply Children
