With the introduction of the Subscriptions Analytics Portal the SELECTserver reports are ending.
As of this time reports are still accessible. However as of September 10, 2019 the report data is no longer updating. You will be able to access historical reports until October 1, 2019 at which time all reporting data will be removed from SELECTserver and only avaliable in the Subscriptions Analytics Portal.
Click here to open the Subscriptions Analytics Portal.
*To continue to your report select it from the list below - there are links on the SELECTserver Admin page.
