We have a local SELECTserver and we are moving to CONNECTION client.
I have MicroStation CONNECT recently installed and it works.
MicroStation v8i license was configured using Product Activation Wizard.
I've tried switch to Evaluation Only - No license information, but really I want switch to: USE CONNECTION Client, please (it's working)
Next step is unsinstall/reinstall, but it must do that with every pc ...
If someone has an alternative ...
The only way to do this that I know of is with the Connect Licensing Adapter, which is a product that Bentley pulled off the download page. You potentially could call Bentley and ask if you could get a copy of that product, but many people there will not know what it is. I had one person tell me that it was never released, but it had been released, and then later pulled off.
--Robert
Answer Verified By: Javier Rufas
Thank you very much Robert,
Hi Javier,
Have you looked at V8i SS10? That is supposed to be the same as SS4, but using the same license. I have never installed SS10, so I don't know if it just updates SS4. I would assume that it does.
