What does this mean? Does this mean I'll be billed for loading Connect Edition 13 V8i at the same time? "Although two usage records are recorded, one for each product, only one usage is calculated as it is run on one unique machine. So the behavior is the same as if two instances of the same version were started at the same time."
Jan is correct. If you run CONNECT and V8i on the same machine (computer) it will record one product usage. If you would run CONNECT on 1 computer and V8i on second computer it would count as 2 usages.Regards,Robert Karpic
