Whenever I started Microstation, I got the message "licensing service failed with error code 32768" error", does anyone know why?
By the way, the Microstation version I'm using is connect edition 13 and the connection client version is x64 10.00.13.017. I also have Microstation v8i installed, and I previously had microstation connect edition 11 on this computer.
There is actually a separate Licensing and Activation Forum where they may be better equipped to answer your question.
MaryB
Hello Shek
The correct version of CONNECTION Client is 10.00.18.13
Please upgrade and try again.
Samir
