I have a license for Microstation V8i (SELECTseries 3) - Version 08.11.09.292 for a particular user account using Window 7
However, the user account is locked and I cannot check the serial number by using activation tools
And I can browse his hard disk
Is there any file that stored the serial number that I can reinstall in another computer?
What do you mean by serial number? V8i is activated by activation key and not by serial number. You just use the same activation key for all computers. License is activated to machine so multiple users on the same machine can activate it without using additional licenses. To recover license from non working computer you need to know it's computer name and name the reinstalled computer with the same machine name. Otherwise if the account is non-SELECT then the license will only be freed automatically when the checkout expires(by default 1 year). https://communities.bentley.com/products/licensing/w/licensing__wiki/20356/where-do-i-find-my-activation-key
https://communities.bentley.com/products/licensing/w/licensing__wiki/7695/activation-of-client-side-products-and-registry-basics
