I have installed the MicroStation & Inroads. However during the proses of my installation, I wasn't asked to input the Activation key to activate it. I believe that I supposed to enter the activation key when I was opening the software for the first time however I haven't seen any box to do so. I do have the activation key from my school. Now when I open the inroads it says that " 7 day trial' however the MicroStation v8i works. How can I activate the inroads ? Where should i go nd what should i do ? Where should I put the activation code?
Hi Araeik,
The InRoads version you're using is the connect edition and it does not requires activation key to activate. You need to register into User Management and sign-in into CONNECTION client and follow the Activation Instructions to activate InRoads.
Regards,Abhishek
