I wonder how does licensing for PowerCivil for Countries work. I am considering to purchase PowerCivil for Poland. However this software is not up to date with other software (no SelectSeries were released). The only one is 08.11.06.27 which is not certified on Windows 7 and has no OverlayTools. PowerCivil for other Countries, ig. for Baltic is up to date (08.11.07.428) and is certified for Windows 7. I was rised on Inroads with English interface so Polish interface is not an adventage to me.
I would like to use PowerCivil for Country but in its latest relase or PowerInroads. I guess I can not purchase PowerInroads in Poland but can I use PowerCivil for Country other than that for Poland with the same license agreement?
Thanks for your advices.
Adam
Adam,
The latest release of PowerCivil for Poland is in production for a Polish interface. PowerInroads is not available in your market, so if you need a English PowerCivil variant based on the 08.11.07 version, then I would suggest using the Baltic version. This should not cause a licensing issue or at worst may require an update on SELECT server. The Baltic version is aimed at the English speaking metric European market and does not ship with any local standards, so you will be able utilize from your current installation.
I hope this helps
Ian
Thanks. It helps. PC for Country is a very powerfull software for an affordable price.
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
