posted on behalf of the user
we used to have a local server for our licensing and now it has changed
to selectserver.bentley.com. one of the machines in aberdeen will not let me change the server and when i try to open the license
tool options, i get a message stating
the following options have been set by your selectserver administrator . users may not c
hange them.selectserver: -server name -site activation key".
i am an administrator and need to remove this lock so the u
ser can continue to work. please advise how to remove the lock.
thanks
This means that the machine in question is getting the licensing configuration via Group Policy and you can only change that on the domain controller. There should be Bentley Licensing configuration where Server Name and Site Activation Key are defined and which you can disable. Please, contact your Active Directory admin reagrding that, here you can find an example video on how that can be configured: communities.bentley.com/.../7763.aspx.
Answer Verified By: Tyler Q - Bentley
