(posted on behalf of Customer)
Can you verify if the access restrictions below actually work? Also, assuming they do work, what sort of message will the end user receive upon checkout if all licenses are in use?
Hi Nico,
The image is a bit blurry, but I believe your inquiry is in regards to Checkout Restrictions.
I can verify that the Checkout Restrictions are currently working as designed.
A detailed explanation on the functionality and use of this SELECTserver feature can be found within the following Wiki article. communities.bentley.com/.../8479.aspx
Feel free to post any follow up questions here if you require more specific information not found in the article.
Hope this helps!
Answer Verified By: Brian D., User Success Support
