Three weeks ago, we have received the mail "SELECT subscription changes for 2014".
We currently use Select Server deployed and manually transmit the usage logs once a month. Our PCs don't have an internet access. Is that use without Internet connexion still possible with your new SELECT Open Access? (it seems that the answer is no)
I have checked that we currently cannot no more download updates with SELECT services (except Bentley iware and Mobile Apps). Do we have to register to SELECT Open Access to have access to the downloads?
TIA
Patr93
Unknown said:We currently use Select Server deployed and manually transmit the usage logs once a month. Our PCs don't have an internet access. Is that use without Internet connexion still possible with your new SELECT Open Access? (it seems that the answer is no)
SELECT Open Access utilizes Bentley's licensing solution on the Internet exclusively. This is done to simplify setup since a local license server is no longer required. However for unique situations where Internet access is not permitted on workstations, I would recommend discussing licensing options with your account manager. I would be happy to arrange a follow-up with your account manager if desired.
Unknown said:I have checked that we currently cannot no more download updates with SELECT services (except Bentley iware and Mobile Apps). Do we have to register to SELECT Open Access to have access to the downloads?
No, download access is a benefit of the SELECT program in general, not of SELECT Open Access specifically. Do you receive an error message when accessing the Software Fulfillment page? If so, please let me know what you find.
Unknown said:If so, please let me know what you find.
At my case ... and I assume patr93 will confirm his situation is the same ... instead of to Fullfilment Center page (or also to old download page) I am forwarded from login page to Bentley free software download page. I created Service Ticket 7000153162 on behalf of this problem last week and also discussed it with Phil Chouinard, but the problem has not been solved yet.
With regards,
Jan
Thank you for your answers.
>>jeremyhoesly
I am in the same situation of Jan. I am redirected with no error messages.
Patrice
Unknown said:I am in the same situation of Jan. I am redirected with no error messages.
I really hope the same problem reported by more different users will help to discover a source of the problem soon.
Interesting fact is we are completely different (I guess) users: Patr93 is SELECT user, but I am BDN member and not SELECT user.
Jan,
I am also BDN member.
It's the proof assumptions are dangerous and not correct often :-)
But anyway we can hope it will help to identify the problem...
