When I use a solid as a clip volume in MS CE, the prompt will be seen as the picture above.
Is that mean the new version MicroStation can't use a solid element for clip volume?
If I use a single surface, like a rectangle surface to be an element for clip volume, it will perform like the clip mask, but I really need the function that the solid element do, just a fixed space inside the volume.
Koalar
René R. van den BrinkTechnical SupportBentley Systems Incorporated
Answer Verified By: Koalar Q
