Where is the Dimension Radial tool? Search doesn't find it. Has it been removed?
Your correct this has been removed, this and other superseded and removed features can be found in the Readme. ( Extract below )
C:\ProgramData\Bentley\Documentation\MicroStation\10.0.0\en\htm\ReadMe\GUID-C85CA707-5B2B-44E7-BA29-2AFFF35D4C4A.html
Radial Dimensions toolbox
The Radial Dimensions toolbox has been removed along with the following tools within it:
•Dimension Radial
•Dimension Diameter
•Dimension Diameter Perpendicular
•Dimension Radius (Extended Leader)
•Dimension Radius/Diameter Note
•Dimension Arc Distance
Note: Place Center Mark is now accessible from the Dimensions toolbox.
Carl Myhill
Technical Support Engineer
Bentley Systems
You can reference in a radial dimension from an older file. I tried it and it worked.
Open the Dimension Element tool. Once you click on the circle or arc it will switch to a radiusor diameter mode.
Answer Verified By: Todd Moser
