Line string editing by selection vertex
Hi
I have a problem with editing line string by selection vertex.
When I edit line string on one computer it's work correctly.
link for work correctly -
But I chanced something on the second computer, and when I try editing line string on this computer, it's work different. And I don't know where is the problem.
link with the problem -
Can someone help me, please.
Thank you
Michal
  • Hi Michal,
    You should have mentioned what version of MicroStation you are using.
    What do you mean by it works differently?
    Can you please elaborate a little bit more so we understand the problem?
    Did you disable the Edit handles on element information? If so, just enable the option to edit handles
    communities.bentley.com/.../missing-edit-handles
    If issue is different please provide more information.
    Maria
    Maria Garcia
    His videos illustrate the question fairly well, don't they?
    Regards, Jon Summers
    LA Solutions
  • Hi Michal,
    The second video was not available when I replied to this post.
    I saw the video now and the issue is not related to enabling the handles.
    It is a little strange, are you using any other combination of keys like (Ctrl +...)  or maybe you have pressed the Alt key?
    If I select the string and after i press the Alt key I get the same behavior by pressing alt key again the issue disappears.
    if that is not the case, maybe this  is related to some kind of UPF corruption.
    Review how to delete tmp file and recreate a new UPF communities.bentley.com/.../8978
    Let me know if this solves the issue.
    Maria
    Maria Garcia
  • Hi Maria
    I use version V8i 08.11.09.459 - here it works correctly
    and version V8i 08.11.05.05 - here it works differently, but it worked similarly on both version few days ago.
    And the problem is illustrated on videos. On first video I can edit line string vertex by using selection function (only vertex), but on the second I can't edit only vertex.
    I hope that I have explained sufficiently.
    Thank you
    Michal
  • Hi Michal,
    Did you try selecting the string and pressing ALT key?
    Maria
    Maria Garcia
    Answer Verified By: Michal Bukovinsky
