To let others know the MicroStation release you are using without having to open the thread, please start the subject of your topic/thread with the following:
[<release>]
where <release> is:
For example, if your inquiry is regarding MicroStation CONNECT Edition, your topic/thread should start with:
[CONNECT]...
If your inquiry is regarding MicroStation V8i, your topic/thread should start with:
[V8i]...
Also, if the issue you are encountering is specific to a product version or OS or computer, please include the following in your post:
