Dear All, I have an issue with installing of Microstation.
The error message always come up as the screen shoot below:
Please let me know the resolution.
P.S: I am Using Windows 7 x64
if you will search communities at this web, you will receive many valuable answers ;-)
Error 1603 during the installation is pretty general and doesn't provide any extra value. I think the most simple solution is to go to an extracted MicroStation installation folder in C:\BentleyDownloads and to start MicroStation installation manually and check what the real error message is.
With regards,
Jan
Thanks Mr.Jan,
I already try to install from C:\BentleyDownloads and to start MicroStation installation manually.
It's still persist.
If you start only MicroStation installation (msi file, not setup.exe), what is exactly the error message you receive?
Unknown said: Please let me know the resolution. P.S: I am Using Windows 7 x64
Do you have Administrator privs. and UAC turnd off?
Frank
It may be worth looking at this similar thread regarding Error 1603 and installations.
Answer Verified By: BruceV
