The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 3 (10.03.00.30) on Fulfillment Center and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition supports publishing i-models for use in Bentley Navigator CONNECT Edition Update 3. In addition, this version of MicroStation CONNECT Edition includes a number of user requested fixes. Please refer to the "What's New Highlights" section below for some of the major product updates and enhancements.
If you have MicroStation CONNECT Edition Update 2 already installed on your machine, you can download and install MicroStation CONNECT Edition Update 3 as an incremental update from the CONNECTION Client. MicroStation CONNECT Edition Update 3 will replace MicroStation CONNECT Edition Update 2. Sign into the CONNECTION Client and refer to its help for information on managing notifications and installing application updates.
Note: MicroStation CONNECT Edition Update 3 requires a few packages that were delivered with MicroStation CONNECT Edition Update 2. Therefore, if you have MicroStation CONNECT Edition or MicroStation CONNECT Edition Update 1 installed on your machine, you won't be able to install MicroStation CONNECT Edition Update 3 directly as an incremental update from the CONNECTION Client. You can update MicroStation CONNECT Edition or MicroStation CONNECT Edition Update 1 to Update 2 first in order to take advantage of the incremental update through the CONNECT Client or you can download the full version of MicroStation CONNECT Edition Update 3 from the Fulfilment Center and run the installer to update MicroStation to Update 3.
If you would like the full installation of MicroStation CONNECT Edition x64 (Full) Update 3, please follow these steps to download it from Fulfillment Center: 1. Sign in to Bentley.com 2. Browse to Support 3. Select Go To Portal 4. Choose Software Downloads from "My Support" 5. Select the Brand MicroStation and then select the Generation of CONNECT Edition. 6. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation CONNECT Edition x64 Update 3 version 10.03.00.30 Important installation requirements and notices are found in the Readme.
For the full list of What's New and Changed please refer to the Help section within MicroStation CONNECT Edition Update 3. Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 3. Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
