The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 5 (10.05.00.40) on Fulfillment Center and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition incorporates a number of new capabilities as well as user requested fixes. Please refer to the "What's New Highlights" section below for some of the major product updates and enhancements.
If you currently have MicroStation CONNECT Edition already installed on your computer, you can download and install MicroStation CONNECT Edition Update 5 from the CONNECTION Client. MicroStation CONNECT Edition Update 5 will replace any earlier versions of MicroStation CONNECT Editions and update it to MicroStation CONNECT Edition Update 5. Sign into the CONNECTION Client to view and apply your Application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
If you would like the full installation of MicroStation CONNECT Edition x64 (Full) Update 5, please follow these steps to download it from Fulfillment Center: 1. Sign in to Bentley.com 2. Browse to Support 3. Select Go To Portal 4. Choose Software Downloads from "My Support" 5. Select the Brand MicroStation and then select the Generation of CONNECT Edition. 6. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation CONNECT Edition x64 Update 5 version 10.05.00.40Important installation requirements and notices are found in the Readme.
Dynamic Views
Detail Scale in Drawing Boundaries
Overlap While Placing Named Boundaries by Length
Renaming Model Automatically Updates Saved View Links
Parametric Modeling
References
Solids Modeling
Ability to Use the Same Element as an Input in Multiple Parametric Features
User Preferences
[Technology Preview] Issue Resolution ServiceIssue Resolution Service is a cloud based service that intends to identify and resolve issues during a project's life cycle. The primary focus of this service is to allow coordination between work in the field and in the office. In MicroStation, for a CONNECTED project, you can now view and manage issues registered by users of Bentley Navigator (desktop or mobile) application, as punch list items. These Punch List Items can be viewed and managed in the Manage Issues dialog in the Issue Resolution group. A Punch List Item is an issue associated with an item documented using Bentley Navigator CONNECT Edition (Refer to Bentley Navigator Help for more information on Punch Lists). You can view details, attachments and comments associated with the punch list items and also add new comments to them as needed. You can upload these comments to the cloud. [Technology Preview] Online HelpMicroStation documentation can now be accessed online. With Online help, you will always get the updated version of documentation. When accessing Online help, you also get other capabilities such as advanced search and commenting. The Use Online Help setting in the Preferences dialog, Help Settings category allows you to enable or disable Online help access. When this setting is on (the default), Online help is opened. If internet connection is not available, the offline Web help is opened.Technology Preview Features Released in MicroStation CONNECT Edition Update 5The following features that were in Technology Preview mode in previous updates have been commercially released in this update:
For the full list of What's New and Changed please refer to the Help section within MicroStation CONNECT Edition Update 5.Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 5. Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums
