How will I remove the comma when placing coordinates using civtools v8?
There is a setting in the "General" tab of the CivTools Properties dialog where you can enable or disable using a comma for the decimal. Are you looking for something other than that? If so, could you provide a screen-shot (or example) of what you are trying to achieve?
I have the some problem ,if not chose the comma ,it will be blank, but i do not want the blank.
I have the same problem. For my stuff i want "COMMA" to show up but it doesn't. i do the find replace to fix this but i still ended up going back and
deleting the comma after the "N/E" at the beginning.
SOMETHING Interesting: This is true when I load civil tools (ver. 08.11.09.04/January 24, 2012) onto my V8i. But when I load it onto my V8 it works as it suppose to.
Anyone have thoughts on this?
