The image shows the results of place coordinates with various combinations of the working unit/design file settings in preferences on or off. None of these give a result that is expected. There should be commas instead of spaces are in the northings and eastings. When working unit format is selected, the results are truncated by inserting a decimal point in the first blank space. And the elevations should not have a space after the thousands digit (should look like the result on the left from the spot elevation tool).
Is this a bug, or is there a way to get commas inserted where they should be, and removed from the elevations? Since working units are design file settings, what is the working unit setting supposed to do?
John described my question exactly. It has been 152 days and there has been no response from Bentley.
153 days and counting...
John,
Sorry for the delay... Do you have the the test file and what fonts you were using (it could be that the comma is not where the application is expecting it to be). In the file can you also hand craft what you want or expect the output to be?
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
I have found the issue and it will be fixed in a future build of the tool.
Thanks John. Will a notice of the new build will be posted here?
