I want to convert a DGN file with tag element into a DWG file along with tag values. Is any option/setting to retains the tag value?
check this and this wiki pages.
Tags cannot be saved to DWG directly, but DWG allows to use attributes in block, which is equal to tags attached to cells. So if you will create cells with tags, they will be converted to block with attributes and the tags data will be not lost.
With regards,
Jan
