I need to be able to use the Arial Font to meet client cad standard. When I use this I do not have access to some of the special symbols that I frequently use (BL CL +- Delta...) When I click on the Symbol list these are not available as options. Is there a way I can add these symbols to the list so that I can meet my clients requirements without having to manually place the symbols separately as cells?
Unknown said:Is there a way I can add symbols to the [Arial Font]?
The Arial font is a TrueType font provided by your Windows operating system, as are many others.
You can edit a TrueType font using third-party tools. However, you would then have a unique version of Arial that you would then have to pass to your customer and customer would have to install it on each computer.
That's probably not an acceptable process, for all sorts of reasons.
Unknown said:I need to be able to use the Arial font to meet client cad standard
What does your client use for BL and CL symbols? How do they reconcile CAD Standards and TrueType fonts that don't include special symbols?
You can (and probably should for compatibility reasons) do the same in MicroStation as your ACAD users do. In the text editor you can insert a symbol into the text body. If the symbol does not exist in Arial, you can switch to a different font and use the symbol from that font. Then you can switch the font back to Arial.
