Need a solution how to avoid automatic renaming of duplicate cells. The cell in attached file UDVENT is correctly created using ByLevel/ByCell attributes but still when converting DGN (normal) cells to DWG(shared cells) it is renamed to UDVENT1, UDVENT2, etc. This is wrong behavior as cell geometry is identical. ByLayer/Byblock symbology is AutoCAD compatible so cells shouldn't be renamed.
Even if cells are different there is need to avoid automatic renumbering and ask user how to solve this issue. MS_RESOLVESCNAMECONFLICT variable doesn't help in this case.
CellNameConflict2DWG.dgn
ByLevel/ByBlock is not the cause of renaming - it is actual levels that are different. The elements in one cell are on level 1_UDTK_ELEM_VENT_####_#, but those in the other cell are on level 2_UDTK_ELEM_VENT_####_#. If both cells must be converted to one single shared cell definition, which is essentially what DWG save has to do, only on level can be used. It is not obviously to me which one to be correct. You are right that prompting you to select a correct level resolves the conflict for this particular file, which has only two cells. But I suspect that it may apply to general cases, files with lots of different levels, different colors, tags, etc, etc. Prompting users to resolve conflicts during a save as process, worse yet during a batch conversion, is unlikely a welcome solution. Keeping content unchanged but renaming them is on the safe side. At least cells can display correctly after the conversion. In your particular case, if you can create shared cells prior to saving as DWG, that would be the best way around this problem. Because you would know exactly which level to use for elements in a shared cell definition. When you create the cell definition, you just need to turn on the toggle "Use Shared Cells". Everything else is the same as far as creating a cell goes.
Both levels are correct. See CellNameConflict-expected-result.dwg file for expected result when saving to DWG. Shared cells are unmanagable in DGN environment, cause lot of issues and would like to avoid using them.
Regarding prompting users to resolve conflicts I would expect that MS_RESOLVESCNAMECONFLICTS or similar variable would be honored when saving to DWG. Need something like MS_RESOLVENCNAMECONFLICTS (where NC stands for Normal Cell) variable to control how to resolve conflicts. But I see that it could be a more complex task when saving as require to compare which normal cells are identical and could be merged as one SharedCell and which are not.
I tried various options when saving to DWG like [Try to] Create Single Block for Duplicated Cells and Create Block Entities with “By Block” Properties but none of them works as expected. These options are not good enough and doesn’t create single DWG block even if cells are identical(geometry) but only placement level differs. Also if Cells are placed using Relative option they are not treated as identical but should as it is how blocks in DWG works.
In my opinion if the cells which are identical, uses ByLevel attributes and only Level differs then they are compatible with AutoCAD ByBlock and should not be renamed. The intelligence of „Create Single Block for Duplicated Cells” option can be improved to avoid creating multiple shared cell definitions in these cases. Also option to use cell definitions from DWG seed file would help to solve naming conflicts in case normal cells are not identical but should be replaced by only one definition. For now I see only option is to use shared cells but it has lot of drawbacks and it is inconvenient.
BTW it is not clear Insert Layer for Normal Cells option should be used. If I set this layer to 0 then all cell instaces are placed in layer 0 and cell definitions are in original levels not useful at all.
I'm not sure what drawbacks and inconveniences you have encountered by using shared cells, but if you have found difficulty to create a single shared cell definition that can represent both of your normal cells, chances are that DWG save process will not be able to do any better. This is mainly because at the root of the issue is a concept mismatch - a normal cell is completely defined by itself whereas a shared cell is only an instance of a cell definition which may have many other instances. Let's take a look at a generic example, two normal cells using the same name with identical geometry. One cell has a circle on level 1 and a line on level 2, the other has a circle on level 3 and a line on level 4. Geometrically, the circles and lines are equal. They also have the same attributes, including ByCell/ByLevel symbology as you have emphasized. The only difference is level. Suppose you were to create a single shared cell that can represent both cells., you must change the levels one way or the other. There is no way you can keep all 4 levels the same in the single shared cell definition. If you were to ignore the level difference, then you'd get a single cell with a circle on level 1 and a line on level 2, or one with the circle on level 3 and line on level 4. But you cannot have all 4 levels, unless you have two shared cell definitions, which is essentially what DWG save would do. The Insert Layer option does not apply to your case - it is used for those who want to force shared cell instances on layer "0" when saved as DWG. It does not change definition - the definition must come original normal cell definition.
I understand that this may be workflow specific but I still think that in case all elements share one level and the attributes are set ByLevel the DWG save process could do better. Not sure how the comparison is done between cells but it may try to ignore level when comparing or have the option that the shared cell instance is placed on the level of the first graphical element of the original cell. This is default behavior if "Insert Layer for Normal Cells" is off so there is need to have additional option to apply this to all cells and use only cell name for comparison.
Main reason why this is needed in DWG save is because shared cell concept in DGN workmode is unfinished/outdated and have issues. Similary as with annotation cells that idea is good but it is not well implemented and it renders them hard to use in practice.
Filed formal Enhancement Request 160892 for this.
