When I save a file as a DWG it creates the file as normal and I can then do modifications on it, but once I try and save the file or close microstation and open the file again, Microstation terminates and a pop-up window saying that microstation has stopped responding comes up followed by another pop-up saying that it can not continue abort, retry, or ignore. It also says it makes a log of the issue in my user folder which is not there. This happens on other computers in the office. The log shows up on my coworkers computer. I sent a service request to Bentley with no response. Exception.log
Is it possible that maybe you can send us your DGN files including reference files you attempted to save as DWG? One way to do that is to upload a zip file to ftp.bentley.com/pub/incoming/ or this communities secured file area. This will allow us to try reproducing your crash.
