I've created a batten cell and used it for pattern hatching. As you can see in the screenshots something weird is happening with the pattern when exporting the file to dwg format. When the cell is placed as a single cell it doesn't get corrupted.
Maybe someone could please enlighten me about the under-the-hood-process of transforming hatch pattern to dwg format as I would like to know how I could optimize the batten cell for export.
By the way: the same things happen when I try to use batten linestyles. In Microstation everything looks great but after exporting it to dwg the linestyle looks the same as the broken pattern.
RegardsStephan
If your patterned element is placed afar from the world origin I might have an answer, but since you have seen the same problem with linestyle this could be a completely different issue than we know of. Can you please upload a simple test file so we can try to reproduce the bad result you have had?
Where did you upload the files? I was told that the SR has no files associated with. I looked at secured files uploaded none of which looked like what you have reported here.
