I am converting DGN files to DWG files. the conversion works, but when I open the files in AutoCAD they're are multiple levels that get turned on or off in AutoCAD that are not turned on or off in the DGN(Microstation). Is it even possible to convert a DGN to DWG and have it look almost exactly the same way? I know line styles and fonts will be different. I just want the right levels to be turned on or off as is in the DGN.
Have you tried these settings?
