I have linked raster images to elements in a 3D model DGN file both jpeg and pdf. When viewed in MicroStation if you hover over an element they show up fine and gives you the option to open the file as well, however when I export to 3D pdf, the links are not viewable. Is there a way to either embed the images within a pdf or attach links and keep the images in a folder along with the pdf so that they are viewable?
Charlie
Answer Verified By: Shaun Bradley
