I am having troubles with my Ctrl+Click command in SS3.
1. Ctrl+Click does not give me the power selector mode add
2. Ctrl+Click is set to undefined in my button assignments
3. When I hard code in my Ctrl+Click to equal PS mode add, it does not work.
Any thoughts would be greatly appreciated. I have been Ctrl+Clicking for about 10 years now and its not something I would like to give up. After going through the archives I believe I found many people with the exact opposite problem as me.
-Dr. Clark
R.E.Y. Engineers
Folsom, CA
I cant duplicate your issue..
Meanwhile in the power selector tool pallet try using the plus sign its the same as the control data feature
the keyin you could remap to button is
powerselector mode add
it works with F key so it should work if you reassigned it by hand in the mouse menu..
Why it stopped working I dont know..
you 'll have to put it back to unselect or set a function key to do the unselect... else it stays in selection mode of add...
Lorys
Unknown said:Thanks for the suggestion but I really do have this Ctrl+Click hard wired into my brain. Also, I guess I didn't make it clear enough (sorry) but when I use the key in for that command, I just get an "unknown command error" As well as, when I create a new user, project and interface.... still no work-y And... when I re-load my UCF and UPF files that have been the same since I went to SS2, it still doesn't work. This is really frustrating because I have been using Ctrl+Click for almost 9 years. Do you happen to know where the line is for this in my config file?
you did try to type the command keyin below into the keyin browser
this works here for me perfect... even remapped to side button on my mouse it worked..
This is the only way I can do it without control + LMB data ... needless to say my control + RMB Data works...
Try replacing your workspace. cfg and upf with a co worker in your team ( make backups first) ... does anyone else have the same issue...
If still dont work then I think maybe your microstation is broken.. and needs complete removal and reinstall .... you may be able to reuse colleagues upf and workspace config and rename them then reset up your workspace prefs etc by hand... a bother but not to painful.
I'm not sure if this will help, but I think the Element Selection tool must be active and the mode set to Single and New.
The keyin to get Element Selection activated is - CHOOSE ELEMENT or CHOOSE NONE
The keyin to set the modes are - POWERSELECTOR SINGLE and POWERSELECTOR MODE NEW
Then I think the Ctrl-Click will work, at least it does for me.
