How to Export to DWG only levels "used" and "on" of several models?
Thanks!
Xavier C.A.
EiPM
Roland
V8i SS4 v.08.11.09,829AECOsim BD V8i
Hi Don and Roland, First of all, thanks for the answers! Well, we try the workarounds explained, and there are our conclusions:
- Workaround merging files: It's an interesting workaround, useful for little projects or few DWG exports. In our case, in a big project, with a lot a continuous DWG Exports, this workaround it's not productive to apply in our projects
- workaround using "global settings": Well, in our projects, the capture in my first post, it is from a drawing extraction (model with a Dynamic view), and we try your workaround, but it didn't works.... Thanks a lot, and best regards, Xavier C.A. EiPM
what about freezing the levels off ?....
What about export to DGN to output folder then use batch processor to merge all the refs then run batch convert on the result or a vba macro to do all the above
Lorys
Mmmm.... interesting Lorys.
Can you explain it step by step? any sample?
Best regards,
Unknown said: Mmmm.... interesting Lorys. Can you explain it step by step? any sample? Thanks! Best regards, Xavier C.A. EiPM
Not really it depends how your data is set up and how consistent it is but the process that others outlined but better done with batch processor to do the merge via commands or a vba macro to do the merge on the batch processor. files list. then use the batch convertor to do the dwg as the last step...
