i failed to publish my dgn to imodel using ABD.
the tip shows:
"Some external item type libraries are missing. Data of those libraries will not be accessible.""Missing external item type libraries:Geostation.01.00"
Geostation.01.00 is a schema file we defined.
Then i try imodel composer. i copy Geostation.01.00 schema file to path "E:\ProgramData\Bentley\imodelComposer V8i\WorkSpace\ECSchemas\Plant".
what is the problem and what should i do?
Thanks.
