Mesh from ContextCapture to Microstation, pattern map gets out of order
Hi
I posted this in "Reality modeling" but did not get an answer, so I will try here as well
I have a problem...when importing a mesh from ContextCapture to Microstation (.obj) and trying to edit it (deleting some of the triangles) the pattern map gets completely out of order.
When importing the mesh the pattern map unit is set to surface and I guess thats why it gets out of order when i edit the surface, but I dont really know.
I hope some of you can help me.
Greetings from Denmark
