When I save from DWG to DGN it moves the text outside the dim lines.
I’m unclear if this is a textstyle issue or dim style issue (since dim styles get their text from textstyles).
Opening the DWG in V8i (08.11.09.357) shows this (correct)
When I do File-SaveAs V8 format (incorrect)
Any chance of you posting a small sample so we can investigate. Without the test sample we are really guessing. To attach samples just go to the Advanced Reply Editor. You can zip both the sample Dgn and DWG files. ACAD 2000 is pretty old.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
dimExample.dwgI am unable to provide the whole file as it contains sensitive data. However, I can provide the part of the dimension in a Dgn.
Unknown said: (Please visit the site to view this file)I am unable to provide the whole file as it contains sensitive data. However, I can provide the part of the dimension in a Dgn.
Why not just ref attach the DWG into DGN .. see what it look like if upon merging the DWG file causes a problem... then undo and leave it ref attached and use level manager to change colours to suit msnt you can use Real colours if you cant match iva colour numbers ...this usually works for me....
Lorys
