Can someone save me this file as the dwg ? I have error still ( in SS3 last )
Maybe i need to delete more meshes ( chairs , sofa ) ?
http://we.tl/4RhXAvCXhI here is the file 51 mb
Martin
I was able to down load it and I compressed it all options then exported to dwg.. crashed at 94%
reopened dgn ref attached it to clean new empty DWG via mstn then merged into DWG ( not recommended but save as didnt work)
it created dwg on screen fine.. saved and tried to open in Acad.2015. file empty no graphics didnt try any acad repair file features as I'm not 100 up with acad just wanted to see if acad recognised it.. tried to open with msnt crashed at 94 %
There are or must be some elements that mstn doesnt know how to convert to DWG... last time this happened to me I found that XM was more forgiving and did convert with out crashes and the converted file could be opened but no idea as to what was missed in conversion... xm uses a different recipe to convert where as v8i uses realDWG.. so if you have access to XM use it for the conversion to DWG...
In my experience this problem most often happened to me when someone else copy pasted from a dwg ref file patterning data into a DGN and when you try to export the dgn back to dwg Mstn it doesnt know how to convert a dwg pattern info its expecting DGN info this is my humble lay person interpretation I know it doesn't actually work that way but its a good way to visualise it...
Also the file was very slow to load in msnt as a dgn and a lot of rasters were missing... its just a floor plan so why are there meshes, even piano keyboard described as a mesh? why not an array or a cell?
Lorys
Unknown said:Thank you for trying this - this is a 2d maked from 3d model ( you try delete meshes ? )- i don't know but maybe because as i know - the base was in Autocad students version or something like this - so maybe this is a problem ?
yes as I said before I had probs when people copy pasted patterning from acad dwg to dgn ... when I had axiom tools at work the dgn repair tool often found these and helped me fix them by removing them or exploding them ...
again as I said before if you try and open with XM and do save as acad it will most likely work for you...
