Does anyone have a document that they could share with do's and don'ts for translating DWG to DGNs?
Regan
In the MicroStation help there are several sections on this topic, just search using ' dwg ' and you will find topics such as 'Sharing DGN and DWG Data' & ' troubleshooting' which may be of help Its also possible to open or reference and work on DWG's natively, so may be there is no need to translate. If having some specific technical issues then review this forum and DWG associated wiki articles communities.bentley.com/.../11396.dwg-microstation Appreciate its not do's and don'ts document, which others may have.
Carl Myhill
Technical Support Engineer
Bentley Systems
Roland
V8i SS4 v.08.11.09,829AECOsim BD V8i
