I cant open or export a DWG file in CONNECT. I get the following error with open:
[test.dwg] is not in a recognized file format
And and invalid dwg seed file when trying to export.
Cant even open the DWG seed files provided with SELECT. I have reproduced this on three different systems.
Hello Loren,
Can you have a look where the MicroStation seed files are located. You can do this with the key-in: $ % explorer $(MS_SEEDFILES) If you can find seed files in that location, please check using the Open/Save options for DWG to see if that location is the same as for the MS_SEEDFILES variable Also please check the accessibility to the TMP location and make sure you have also write access to that location.
If these suggestions don't help solving the issue, can you send us a debug file. You can create one by adding the swithc -debugfileopen to the command prompt Have you done a 'standard' installation?
René R. van den BrinkTechnical SupportBentley Systems Incorporated
Hi Rene,
