I have an AutoCAD file with an embedded raster and I need to extract the raster from the file because Microstation will not recognize the raster. As it is currently I cannot do anything to the raster.
How do I get that raster back in a conversion to Microstation DGN files?
Autodesk Raster Design is a product that creates embedded raster objects which can only be enabled by its object enabler. You may find Autodesk Raster Design object enabler from Autodesk website, but be prepared that the OE may not work. Last I remembered, the said OE was not a true object enabler per Autodesk's own definition of an object enabler. An object enabler should only depend on RealDWG, not on AutoCAD specific parts such as its GUI etc. The Autodesk Raster Design OE I had last seen depended on AutoCAD. It did not load into RealDWG. Therefore it cannot be used in other RealDWG applications except for AutoCAD. Autodesk has been made aware of the issue but did not indicate to us whether or not the issue would ever be addressed. My recommendation is that if their latest OE still does not load into RealDWG and you are an Autodesk Raster Design customer, you may want to request Adesk to fix this OE so that you can use it beyond just AutoCAD. Odds are that they may listen to you as a customer.
I think your only real option is to contact the acad dwg author and ask for the raster and if possible ask them to trace a polygon around the raster edges.. just in case its not geo referenced, or if you can open the acad file in acad your self draw the polygon yourself and also ask for the source raster to be sent to you.. then after conversion you can open the dgn file and reattach the raster yourself either georefed or manually by the polygon... best one can suggest without a copy of the dwg and dgn to look at what is happening...
Lorys
Shawn
