I have experienced problems with dwg references in the CONNECT edition (all the connect applications, Microstation, openroads, AECOsim.)
The connect editions are very slow when attaching dwg-files and very often crash. Sometimes it can take several minutes longer time to attach a dwg in CONNECT compared to V8i.
Have someone else exporienced this?
Interesting problem.
1. Would it be possible for Mstn to save the parasolid data in the dwg after the first time the dwg is opened or referenced in Mstn? Sort of a Object Enabler for Mstn?
2. A multi-threaded batch converter to convert the dwg's to dwg's with parasolid info.
I am sure that the removal of ACIS from Mstn has good reasons behind it, but there should be some compensatory measures to offset the effects of this move.
