create "polygon" mesh
I need to take a 3D model and export it to dxf so that I can import it into FEM analysis software, the software is very picky and the 3D elements have to be "polygon" meshes. All i can seem to create are 3D elements that export as "polyface" meshes.
I exported a model from the analysis software to try to reverse engineer the elements i needed to create Element Information shows polygon and polyface meshes as "mesh" so i cant differentiate the two before i export. All the elements the analysis software exported import back and and all my new elements were ignored.
1. What 3D elements in Microstation export directly as a dxf polygon mesh.
2. is it possible to convert objects, eg, 3D solids, to polygon mesh elements.
Parents Reply Children
