Hello i received big size file ( not so big in fact i had my larger many times )
File is done in Autocad propably 2014 . And its very, very slow to open.
In Ms V8 is not so good but "ok", few minutes... but in Connect about 20 - 30 minutes.
I try save as dgn, make cleanup, compress but after - file is about 100 mb bigger than orginal dwg
Can someone check what is wrong with this geometry ( file is for download here ) for a week https://wetransfer.com/downloads/190bbb5ad8840203b6c2a5bdf086a89520170302070518/050a83cc78a10ab3875290eebdf58d4720170302070518/9dec05
I'll have to figure out the approval procedure of accessing wetransfer, but wondered if you are able to post it to the secure file area that has already been approved for us to use?
