I have some acad files I need to convert into dgn files BUT I need them to use the correct global origin. I start a new file using the correct seed file then attach the dwg. This is where I'm a little confused. How can I be sure that the acad file is being attached correctly meaning using my seed file? How does Coincident and Coincident-World play into it, if at all?
Thank you
MaryB
I had issues with acad DWG conversions or even just ref attach dwg to dgn and they never came into the right coordiantes..
part of the problem is we workin civil and use meters and coodinates in meters.. acad is unitless and even though acaders treat the coordinates system xy as if they were in meters so I the options for open acad I set it to meters and now they come in perfect...
I alway pretest out of habit by creating a new dgn with the seed file set to our datums and then ref attach the acad coincident and then merge the ref or copy it through and detach.. I prefer the merge as I doenst take on the the acad colour table like save as or convert does so I can then just rename levels and use our dgn lib to resymbolise to standards colours.. this seems to be the most efficient way I've found so far... the acad colour table thing really bugs me as I ahve to then attach the standards or client msnt colour table to it ! these are extra steps and it all adds up at the end of the day...
Another Trick is to open the dwg first with microstation and label a point with coords that you know exist in the your dgn world then when you convert or ref attach you can check the known point... the only other thing is when acaders have drawn the acad as if they were in mm then its trial and error changing the ref attachment 1000 times scale etc...thats why I prefer to ref attach rather than convert...
If I have to do lots of them then I random check a few with ref attach and if all good then I use the batch convert with the meters option in the dwg open option...
havent had iny more issues for 11 out of the last 12 months since I found the setting and I use acad files all the time everyday from our local 12D road designers...
I'm the lone mstn guy in the team the other acad drafters just use the acad dwgs no issues for them but I'm there for the DGN prefered clients like DOTs etc...so I had to figure out how to adapt... so far so good....
Lorys
